PiratePast40
- Joined
- Mar 21, 2009
- 1,734
Engine is a Volvo AQ130D and the outdrive is a 280. Just put the motor in the boat and reassembled the lower and intermediate housings. I hooked up to the muffs and no water flow inside the boat. Disconnected the hose going from the transom plate to the strainer and no water at all from the outdrive. Hooked the garden hose into the strainer line back to the transom shield and get a good stream out the bottom of the outdrive.
Nice strong water pressure at the hose and water comes out the hole in the bottom of the drive when the muffs are hooked to the inlet vents.
As far as I can tell, there just isn't anything in the outdrive that would act as a check valve. But why can I only get water to flow one direction?
