OMC Ford 302 Manifold - using Barr Indmar from Osco??
34_South
So, my much anticipated manifold/riser kit from GLM arrived. I noted the mating surfaces to be really bad - su much so that I contacted GLM to obtain replacements.
Then, a tech suggested using a Barr/Indmar universal setup from Osco. Now it seems as if it could work - with the only issue being that I would need to find a way to mount the circuit breaker box, since that used the riser bolts to mount previously.
Here's a link to the Osco pdf - the tech said items 1, 4, and 7, plus gaskets, etc. http://www.oscomotors.com/catalog/pdf/osco-pg26-28.pdf
Has anybody used this Osco setup on an OMC/Volvo Ford small block? Any problems? While it is more expensive than the GLM, I think it might be the better option.
34S.
puma1955
Re: OMC Ford 302 Manifold - using Barr Indmar from Osco??
I bought my stuff from E Basic power 5.0L ford 302 GLm risers and manifolds with no problems at all.
Manifold, Exhaust Kit, Volvo Ford 302 5.0L, 351 5.8L V8 Carbureted
Code: BPIFSBVOLCARB
Weight: 114
Price: $669.00
Quantity in Basket: none
Manifold/Exhaust Kit for Volvo Ford Small Block V8 Carbureted with Center Rise Manifolds (will not work on EFI)
Includes (2) GLM51490 Manifolds, (2) OSC50456 Risers, and all manifold and riser gaskets.
Here is the site: http://bpi.ebasicpower.com/c/VOL8A/Manifolds+for+Volvo
