fuel question
chief08087
got a problem with motor loosing fuel when wide open. 86 evinrude 225. just really wanted to know what the brass fitting is on the block that connects the pulse line to the fuel pump. is this a check valve or something.
samo_ott
Re: fuel question
in a 225 I can imagine that most of your fuel is going straight down the many carbs!
Re: fuel question
what do you mean, "loosing fuel"? leaking, using more than you think it should? running out of fuel, not getting enough to run wide open?
chief08087
Re: fuel question
i just wana know if that fitting can make the fuel pump not pump when running wide open.
chief08087
Re: fuel question
for some reason my carb bowls go dry when i run it over 4000rpms. i pulled a fuel pump off a motor that i know works fine and still the same. has all new lines on it. why am i not pumping fuel at full throttle?
Re: fuel question
vent open and clear on fuel tank? arrow on bulb pointing toward motor?
chief08087
Re: fuel question
yeah. im even using a temp tank at the moment. i just dont get it.. am i loosing pulse at full throttle somehow?
Re: fuel question
Lots of reasons for lack of fuel flow. Start at the fuel tank. 1) clogged fuel pickup screen, 2) sticky anti siphon valve, 3) fuel line degradation, 4) check valves in primer bulb restricting fuel flow, 5) air leak in fuel lines, 6) water separating fuel filter needs changing, 7) fuel filter on the engine needs changing, 8) engine mechanical condition (low crankcase vacuum) at pulse line. There are some of the primary suspects.
jonesg
Re: fuel question
a clogged vacuum check valve can do that, try removing it and blasting it with carb cleaner, it should only blow thru one way.
Clean the hose too,
...the manual advises just installing a new one,
it can be critical and its cheap anyway.
chief08087
Re: fuel question
well i took that chek valve off this morning. if its supposed to be a one way than mine is bad because i can blow through it both ways
chief08087
Re: fuel question
and by the way that pulse fitting doesnt blow one way. i got a new one and it blows both ways. engine is about to become an anchor
