Hey guys, I have an '84 Evinrude 50 that shifts into forward just fine and drives fine but when i shift into reverse it just clicks, no reverse at all. I removed the cable and shifted it manually and the problem still persists. If i push fairly hard on the shift linkage, the gears seem to mesh a little better but not quite go into gear. What I am wondering is, is there a way to adjust the shift linkage by removing the lower unit or does it need to be taken apart and rebuilt. I have solved several problems by cruising the posts, but this time, I'm in a pickle. Thanks
