Re: Hyd. / man. steering
I just found out (from Teleflex) that the early cable steering systems had a grease fitting on the rod tube. If it's overgreased (like any extra grease at all) the excess grease is forced into the cable, causing it to "hydraulic lock" and become dificult to steer.
As mine got stiffer, I greased it more, making it worse.
Their solution is replace the cable.
My solution is to rig up a reservoir made from a steering (tilt) tube, or even just a hose, to force penetrant through the now disconnected cable with compressed air, then follow it up with a light oil, or even just leave the wd40 in it.
Then remove the grease zerk and discard it, plug the hole, and maintain it as the cable instructions say, that is to pull the cable, clean and lightly grease the tube, and reinstall the cable.
hope it helps
John
