Nandy
- Joined
- Apr 10, 2004
- 2,145
I am actuality polling all those great glass workers here that care to comment.
I saw some of the pictures from Yatch Dr and saw where he is vacuum sealing some sections of glass. I had envision a similar process but obviously there is a system out there already built for this. Yatch Dr, Can you care to elaborate a bit on the rig you are using and the process? Anyone else using similar equipment is more than welcome to comment.
I was thinking on using a shop vac and maybe some of the valves that comes with the storage bags meant to shrink their content by means of vacuum. I would have buy some of that .7 mil plastic and duct tape it together for some sections or duct tape the plastic to the side of the boat as Yatch Dr does in that picture. Does a shop vac creates enough vacuum? Can anyone comment on those valves? What do you use so the vacuum pulls air from all sections? I was thinking on using 4x8 pieces of foam with some release agent...
Im sure that gear is built for this while I am thinking on jerry rigging mine. Your thoughts might save me some time.
