Can I use this drive???
ColaTM
I have an '88 OMC 3.0L with a good motor but bad upper drive unit.
I found an '88 OMC 5.0L with a bad motor but good upper drive.
Can I use this or no???
Thanks!
7designs
Re: Can I use this drive???
Rebuild the 5.0 and enjoy more power :)
ColaTM
Thanks for the info.
What if I bought the entire 5.0L outdrive? Would that bolt on to the 3.0L???
proshadetree
Will bolt up but youd have to change prop to help with dumped up gearing which in turn would be cost of prop and unit to not funtion like it should.Rebuild your unit.
