Re: 1955 Johnson 10 hp Oily/Watery foam from shift handle
Paul,
I run mine at 24:1 with good TCWIII oil (32 oz. of oil in 6 gallons of gas). I find the synthetic at various places---most outdoor sports stores that sell any 2-stroke oil will have it in some kind of brand. It produces less smoke and less crud out the exhaust, and supposedly more biodegradable than regular oil.
I "restored" those motors myself, but they are not really full restorations. I didn't replace any rings or internal engine parts. I just resealed the lower unit, replaced the ignition parts, cleaned the carb. and replaced fuel lines, pull cord, and anything else that was broken or worn out, then repainted and put new decals on it. I have used it extensively since that picture so it doesn't look as nice as it once did, but it has never failed me and I've run at least 6 or 8 6-gallon tanks of fuel through it duck hunting and such, and the lower unit oil has absolutely no water in it after all that use, which I'm pleased with. The '57 18hp I use regularly and it's my favorite motor of all time. I really like the '55 model 10hp, too.
VicS. gave you good advice as usual, and I agree with him that your motor is probably fine on the cooling. It's the cylinder heads and cylinders which should be the tell-tale on the overheat. If you can hold your fingers on them for 3 seconds with no problem, and it seems to be pumping plenty of water out, then you should be fine. Those numbers on the carb. cover plate are absolutely useless in my opinion. If I were you, I'd look at the "top secret files" thread at the top of this john/evin. forum and find the carb. adjustment thread by Joe Reeves. It is really good in helping you fine tune your carb. adustments. If you have any questions on that motor as you go through it to get it in reliable condition, just ask. I think the OMC manual is by far the best.
Later,
JBJ
