Re: Do I need trim tabs?
Need more info to answer your question, things like; engine make and model, rated wot rpm of engine and can you reach that wot, what prop are you running, boat make, size and weight, normal use and load. The reason this is needed is that tabs can increase speed a little but not really enough to justify the cost and you do not need to bandaid a problem with the rest of the equipment, the results will not be satisfactory. I have Smart Tabs on my boat and love them, they do a lot more than add a little speed and with that said until I know that everything else with your boat is right I won't say, go out and buy them. I am not trying to be hard on you just trying to get enough info to help me and others here to be able to answer your question.
