So based on all the help I've gotten so far. I decided to add a tach so I can check RPMs at WOT and just for the coolness factor. Undid the rats nest of wiring the PO did and made a nice switch panel and wired the tach. The gray wire still had the cover on it. Wired everything up, turned ignition, the tach went to zero. Then turned the motor over but nothing from the tach, still at zero. Checked wiring, all good. Did voltage check on battery (hadn't done this before). Voltage with motor off was 12.8, voltage with motor running, 12.6. Ah ha, not charging. PO had wing nut on negative lead, which I replaced after some previous reading. Stator "looks" good, no goo or anything leaking out. I'm going to change the rectifier and see if it works. Now, here is my question (finally):
Looking at http://www.iboats.com/Johnson_Regul...9398597--**********.714465346--view_id.271366, they say its a 12 amp system. Found the actual part number from engine diagram and did google search, all the other sites say 6 amp. Which is it? Will it screw anything up if I put a 12 amp on a 6 amp? (I'm assuming YES!) I'll defer to the vast pool of knowledge in these groups. Thanks!
