2000 F40 propeller
fixer2
I have a 2000 F40 Yamaha .....maybe 225 hrs.....on a 16 ft aluminum side console.......boat alone is maybe 550lbs....the prop is 10 5/8 x 12.....Engine will go over 6300 if I let it...I keep it below 5500.........wot spec range is 5000-6000
So if I went with 10 1/4 x 14...would this drop my rpm 400...... to wot approx 5500-5600.....
I guess best way would be trial and error.......thanks Phil
QC
Re: 2000 F40 propeller
I moved this over to the propeller section fixer . . . more action for your question here.
hwsiii
Fixer, you said it will turn over 6,300 RPM so I used 6,400 RPM as my base RPM and I ran some numbers based on this. You can expect a change of about 750 RPM by changing from the 12" pitch prop to a 14" pitch. Here are the numbers.
Prop Change
H
fixer2
Thanks H
Thats Cool!......I should have told you my Gear Ratio is 2.0.....Phil
hwsiii
Sorry, here is the right RPM change, and you should see an RPM change of about 700 RPM.
Prop Change
H
