Engine surge
washrag013
Can anyone help??! I have a 1994 60 hp evinrude outboard that surges at full throttle. Pull back to half throttle or below and seems to run ok. go back to full throttle starts surging. When first start it does ok, but after a little while it starts doing it. ANy help ??
chad4050
Re: Engine surge
ok i have the same problem does yours miss at half throttle because mine does let me know and possibly we can figure this out together
washrag013
Re: Engine surge
I can't tell that it does. Its seems to run smooth at half throttle and lower.
Re: Engine surge
check fuel tank vent, can't pump fuel out of a vacuum.
kenmyfam
Re: Engine surge
And if venting is O.K. then maybe the fuel pump is giving you some warning signs.
Bifflefan
Re: Engine surge
Surging is caused by a lean fuel condition. Check the tank vent and then the pump and then the jets. Could also be a colappsed fuel line.
But anyway, the surge means its running lean.
washrag013
Re: Engine surge
Thanks everyone!! The venting is good. What is a good way to check the ful pump ?
Bifflefan
Re: Engine surge
Cant help on the fuel pump testing, as im a 4 stroker.
Re: Engine surge
the easiest way to see if it is pumping, is the turn the red handle on the primer 180 degrees, and pull the primer hose off the top carb. now just turn the motor over, you should get good strong spurts of fuel out the hose.
ezeke
Re: Engine surge
Most surging is caused by air leaking into the system or, sometimes, the fuel pump can't keep the float bowl full at WOT. Work on restrictions in the line from the tank pickup to the pump. If you have a built-in tank, check the anti-siphon valve and the pickup screen.
