1987 mercruiser no reverse
coyotehead
I just purchased a 1987 wellcraft with a mercruiser alpha one with a 305 engine.
I had to build a new motor before I could try it out.It goes in to forward fine but nothing in reverse.Doesn't even try to go in reverse.Seller said lower was recently redone. Any help would be great...
incrediblened
Re: 1987 mercruiser no reverse
Sounds like a lower shift cable. Kit costs about $70. It's a job.
coyotehead
Well,let me ask you this...I can remove the cable from the shift plate by motor and still can't shift in to reverse...Does that still sound like lower cable?
Thanks
incrediblened
Are you sure that you're pulling the cable all the way into reverse? It may be stuck where you can't pull it all the way by hand. This is what happens when your lower shift cable goes bad, and causes shift problems where it won't go directly in/out of gear.
coyotehead
No,Im not sure I guess...I have pulled pretty hard though...I will check that out.
Thanks
coyotehead
Yea,I tried pulling it real hard by removing the end I put pliers on it and pulled good....It seems to be moving the coupler in it full range...Im lost!!!
Evinrude Boater
Did the seller say it shifted after the rebuild? I'm wondering if the shift shaft in the lower gear case got turned back a bit from forward and the upper shift arm is aligned with the wrong splines now. So instead of shifting into reverse it only turns the shift shaft back to the neutral position. They have to be in full forward when the gear case or outdrive is removed. Unless the gear case was in forward when it was put back on it won't be aligned properly.
coyotehead
Wow,that was it and also the fact that the coupler is wore out at the top...It has a lot of back and forth play there...Would that be a slight problem?
Ayuh,... It don't move awhole lot Normally,.. So,.. Any Play is a Potential Problem...
coyotehead
Some one told me to pull with pliers to see if it was stuck I don't know...I do not have the manual man...The drive is on the boat now...I removed the lower to make sure I had reverse and it does...Works great!!!
Bt Doctur
Click on my link above, that is the full manual
coyotehead
Where the coupler meets the upper shift arm there is slack and the splines seem to have back and fourth play as well...Does anyone have an idea of cost for those items?
Bt Doctur
where are we talking
Bt Doctur
this pic
coyotehead
A and B seem to have lots of slack in the splines and where they meet
coyotehead
I found that the coupler and the shaft going in to the upper were bad so I replace them but while having it apart I found that the cable was not installed correct....Put it all back together and it shifts great.
Thanks for every ones help
