EZ Load trailer issue
Last Dollar
I have a tandem axle EZ Load under my 21 Sea Ray Cuddy. It seems everytime I load the boat now it is not level on the trailer when I pull it out of the water. The boat sits level in the water, the rolls and arm assmeblies are all the same distance apart on each side. This is something that has happened only for the past year or two. I have owned this rig 15 years. It used to sit very level on the trailer with no problems what so ever. I liked the EZ Load. Now I'm getting tired of seeing my boat sit cocked sideways on the trailer all the time!! Anybody have a clue??
APPALOOSA2
Re: EZ Load trailer issue
Have you looked at the trailer with the boat off and checked all the rollers and the height from the trailer frame of each roller arm ?
Is the boat sitting more on the keel rollers in the center than rollers on the arms ?
kenmyfam
Good points.
Are you using guide on's at all ??
Is it just not sitting central on the trailer ??
a70eliminator
Have you changed your technique at all, excessive powerloading the straboard side will torque up and may cause an uneven cradle.
mla2ofus
I suppose you've measured from the tlr frame to the ground to see if you have a cracked spring leaf.
Just a thought,
Mike
