Smig
Thread starter- Joined
- Nov 13, 2005
- 182
['76 850 (85 hp) on a 16.5' Tri-hull. SN in signature]
I have been messing around with this for a while and suspect that I am missing something, so I am trying to put together a good trouble shooting list ...here are the symptoms:
1) Sometimes the engine will bog & die out of the hole, but it doesn't always happen. When it does, it only occurs when I try to accelerate quickly - I can put the motor in gear and accelerate slowly without a problem but if I try to accelerate quickly, it will bog & die.
2) The bog & die happen together - if it I try to back off when the bog happens, the engine will still die.
3) Neutral idle is around 800 rpm, in gear it is about 650. I can criuse forever at 650, but the bog happens immediately on acceleration (ie: not at 2k or 4k rpm). I tried raising the idle (1100 neutral/950 in gear) but this does not change the problem.
4) When the bog & stall does happen, it is with a large load (people on board or a tube/wakeboard in the water.) I have never had it happen with a light load.
5) After a bog & stall, I have to raise the warm-up lever all the way up, otherwise it won't restart.
6) When it's happening and I do manage to get the boat up to speed, the engine might stall when I come back down to an idle.
7) The plugs have always been inconsistent (both cyl to cyl and day to day): sometimes wet, sometimes dry, but usually wet.
8) ...and the most bizarre (perhaps unrelated??) symptom. Last fall while fogging the engine I noticed that when spraying into the bottom carb, the engine did NOT change speeds like it usually does. When I sprayed the top carb, it bogged down, but when I sprayed the bottom carb, it did not.
So this is what I have done:
A) I decarbed, rebuilt the fuel pump & carbs and replaced the bulb (it had failed.)
B) I have linked & sync'd several times (using Clams' method.)
C) Boat is propped for 5500 rpm max.
C) Blue spark on all 4 cylinders can jump 1/2" (on the muffs.)
D) Compression is good/even on all 4 cyls.
So I'm not sure where to focus - fuel or ignition, so my thought is to put together a good troubleshooting sequence (for both driveway and water tests) and start at the beginning, one thing at a time to see if I can isolate the problem.
Thanks
Shaun
Thanks
Shaun
