unburnt fuel coming out of exhaust snout
bman1bpm
Motor 1979 140 chrysler. I have unburnt fuel dripping out of my exhaust snout..and the motor runs quite rich. my floats are adjusted slightly leaner than parallel to the carb body. How can I fix this?
Unbalanced
Re: unburnt fuel coming out of exhaust snout
I'll bet you a box of doughnuts that the fuel pump diaphram has a hole or is torn.
bman1bpm
they're brand new actually... One pump was leaking so I replaced the diapharagm and gasket a second time.
Unbalanced
I had a brand new one fail on me. Turned out to be the bolt holes in the diaphram were too small and when I assembled the pump, the diaphram tore. Just a thought. I'll still make good on the box of doughnuts...:D
bman1bpm
haha the bottom one was good, but I've got 2 fuel pumps on the 140 I can still check the top one. motor runs good, just little rich, and uses a lota fuel
eurolarva
Try doing a decarb on the motor. Not sure when it was incorporated but if it has a fuel recirculation system check that to see if it is working properly.
bman1bpm
not sure if I hve fuel recirculation. I probably am in need of a decarb I'll give that a shot this week.
