So, first of all let me say, the shop is on crack for charing 400 dollars to rebuild 3 carbs, this was cake. I was expecting it to be much worse. Ive never done it and it took me 1 hour to tear down and about 2 hours to put back together. I cleaned everything out, used a thin wire from a bread tie. Worked perfect, there were some clogs. Some loose screws and the gaskets were saturated.
I did the little blow trick, everything seams fine. The little line that comes from the shrator valve was clogged on all three carbs, TINY little hole.
So I fire her up for about 10 seconds. Looked at the carbs and the front of them was wet already, so somehow for whatever reason fuel is coming back out of the carbs and then dripping down the air box and soaking the gasket then leaking down under the motor and geting my new hoses wet, cause none of my work was leaking.
What causes the fuel to come out of the front of the carbs? Thats my question.
Thanks a lot guys
Btw I have the early model carb without the jet on top for my 70 Evinrude 89
EDIT: I bet thats why it's flooding, I mixed it 2 quarts lean today and it still smoked rich, and its horrible on fuel. I can burn 9 gallons in an hour or 2. It's going in the airbox and some of it is dripping down and some is getting sucked back in through the air intake. Aye?
Thanks a lot guys
