brooksdonald
Thread starter- Joined
- May 26, 2007
- 6
1999 5.7 EFI Mercruiser, Bravo 3
I had this engine rebuilt (new block, exhaust manifolds, ignition control module) rebuilt by a certified Mercruiser repair facility in summer 2007. Motor ran fine last year (about 15 hours) but took it out last week and had problems. After running around 4500 rpm for 3 or 4 minutes, ignition circuit breaker tripped and I reset. Engine would then not run over about 1200 rpm. Mechanic thought he had found a loose ground that was causing it but same problem occurs after running at high rpms for 3+ minutes. Temperature remains steady (170-175). Any help would be appreciated.
