woodnknots
- Joined
- Oct 20, 2006
- 96
Okay, so I've been reading some of the old posts about buzzers and trim being related, and they all point to the oil level setting off the buzzer (as opposed to overheat). When my engine (yamaha model 200txrs) is at idle I can trim it all day long with no buzzer. When it is at anything above idle and I trim it, buzzer the instant I touch the trim switch.
After reading all the posts about similar issues, I went out and checked all my wiring (this is only about 30 minutes after I re-verified my original problem on the hose and muffs) and after tinkering with all the wiring (not actually connecting or disconnecting anything) I restarted my motor and could not duplicate. Before I say that I (accidentally) fixed the problem, can anyone please give me an idea what was causing it in the first place?
Before I get the lecture, I do not have any yamaha controls. I can't afford them. The motor was a replacement for a set of 1978 johnson 55's and I got a tremendous deal on it and used all the old engine controls and added a trim switch using a momentary switch that was a spare consumable part from a Navy C-2 which I work on. I've run it in this configuration for 2 years with no problems and I take it out at least 2-3 times a month, depending on gas prices. this problem came on literally out of the blue this week.
