armyH20Dog
Thread starter- Joined
- Jul 4, 2009
- 1
I have a 1997 90hp Merc that i bought new in 97. Every year it gets winterized as well as checked out before i take it out in the spring. I am unsure of the total hours I have on it, but I know its alot.
When I took it out for what I believe was the 4th time this year. It started great and ran perfectly for about 5 minutes on plane, then died. I checked the bulb and it was soft. Thinking I ran what fuel was in the motor, I re-primed the bulb and it started right up. Again I took off and after about 500 yards it died again. When I checked the bulb it was firm and I started it back up. This time, when the motor started, I noticed there seem to be a ticking sound coming from the motor. At this point I headed for the ramp. The motor seem to run fine at lower RPMs (aside from the ticking sound).
When i got it home i changed the plugs (they only had about 4 hours on them and looked good), changed the fuel filter (also new) and added a fuel treatment in case i had water in the fuel due to the heavy rain we received prior to taking the boat out. I stared and ran the motor at the house with the hose hooked up to it. It started fine, but again it died when it got up to about 4000 rpms and the ticking is still there(it sounds like its coming from the power head). In the 12 years i have had the motor, I have never had a mechanical problem.
I am currently not working due to an injury, and can't afford to take the motor in and get it looked at. Is this problem im having a minor problem that i can fix myself, or is my boat sidelined till I can afford to get in the shop. Any ideas that y'all might have would be most helpful.
