soaringhiggy
Thread starter- Joined
- Jul 1, 2009
- 167
Ok, first time here, and I am sure this has been done a million times, but I could use some help.
New to me 87 sea ray sorrento 21 foot s21
5.7 liter 260 hp
alpha one with a 1.5:1 ratio
al prop 21 pitch 4878122 A40L 21P (dia 13.75")
centerline 20'8"
beam 96"
dry wt 2820
gal full 40
WOT is listed as 4200 to 4800 RPM
Other info:
I live at 4300 feet
2 adults (well by years anyway) 2 kids
Tech info as I know it:
given approx 3% hp loss per 1000 feet 12% loss (approx 31 hp) 260-31=229 hp
As far as I know the carb has not been rejetted
I am getting a WOT of 3000 rpm, engine is running well.
Once the hour that seems to be needed is over and the boat is on plane pulling a tube with 2 people I can throttle back to 2500 and run there with no problem.
Prop is to large.
ok if my thoughs are correct each pitch give 300 to 400, (lets call it 350 for ease) rpm reduction or increase, depending on which way we go, therefore if I go to a 19 pich prop it should give approximate 1050 rpm which would give a wot of 4050, still a bit low but may be livable.
Should I go as small as an 18? seems to me that top end would be much reduced at that point.
back calculating from here with the reduction ratio if 1.5:1 my prop is turning somewhere between 800 and 1100 rpm less than it is designed to at WOT, no wonder it wont come out of the hole.
Suggestions??
What would the advantave of a stainless vs al prop be?
3 blade vs 4?
If I am off the mark here tell me so I can learn!
Thanks
5.7 liter 260 hp
centerline 20'8"
beam 96"
dry wt 2820
gal full 40
Other info:
I live at 4300 feet
Prop is to large.
Suggestions??
3 blade vs 4?
Thanks
