`Mike Burke
Thread starter- Joined
- Apr 23, 2009
- 10
I have a 94 sea rayder f-13. The boat originally had a 90 horse power sport jet in it. I put in a 96 sport jet 120 xr. The only problem that I have now is at wot the boat goes 36 mph. If I back off the throttle a little bit the motor picks up rpms and tops out at 41 mph (this is with one adult). So why do I have to back off the throttle to get more rpms. I just rebuilt the carbs and put them back on, they are in sync. I just don't understand because it has a throttle stop so it's not like the butterflies are starting to close from over throttling. Throttle cam is in line with roller. I know the timing is 32 deg. btdc while cranking and 30 deg. at wot. I don't know if it's retarding itself too much at wot. I plan on checking timing soon. Here's what I've done so far. New plugs, rebuilt carbs, new fuel pump, new fuel filter, new starter, new starter selonoid, and it has the blue stater. Impeller to wear ring is fine and would'nt cause this problem anyway. Could the rev limiter or coil pack be doing this. Engine starts great (hot and cold). The only thing I have'nt replaced yet is the plug wires. And probably will just order anyway. Any help would be greatly appreciated, I have a service manual and I'm stumped!
