Snowfish
- Joined
- Jul 3, 2009
- 234
Looking some wisdom here???????..
I have a 1998 60hp Merc (3cly 2stroke, not big foot) on my pontoon. While at WOT, after a period of time, it will fall flat on it's face, sometimes. Like it's starved for fuel. Or sometimes it will run fine at WOT until I back off a little. Then it falls on it's face again, sometimes. If you catch it, and throttle back, it will spit once or twice, and then idle fine. It will idle all day long, but try to throttle up, and sometimes she goes, others you have to work it a bit. Sometimes I have to hammer it to get it to throttle up. Others it's more of feather it up.
I've cleaned both tanks, to remove floating sediment and debris. I removed, rinsed and blew out the fuel pick ups in the tanks. In addition, I replaced the fuel filter. I cut apart the old filter and saw some debris, but not a huge amount. My tanks did have a bunch of random crud that was obviously plugging the pick ups.
I thought perhaps I'd missed some of the "floaties" in the tanks the first time. But it acts the same on either tank.
I'm thinking there's some debris in the fuel pump that sometimes blocks the flow and other times doesn't, depending upon rpm or maybe wake action? So, fuel pump rebuild or maybe just a good cleaning?
Or the carbs need to be tore down and rebuilt?
Any insights, comments, and wisdom would be greatly appreciated.
