Tao of Funk
Thread starter- Joined
- Nov 8, 2007
- 58
1976 Evinrude 70hp
I have rebuilt the carbs (correctly I believe), replaced the fuel lines, tested the fuel pump, and checked for proper spark.
When I try run the motor up to full throttle (in the water and in gear) it bogs around 2000rpm. I had a friend in the boat today and I had him advance the throttle (in gear) while I blocked the carbs with my hand. When I restrict the air flow to the carburetor the cylinder fires and the motor accelerates. It seems as though the increase in suction allows the fuel to pass more readily through the jet. I adjusted the float to allow more fuel into the float bowl and it didn't help. I adjusted the float to lower the fuel level in the bowl and it didn't help. Once the engine achieves full throttle/cruise speed, whatever you want to call it, it'll run all day long up there. It'll idle all day long too.
I double checked the carburetors to ensure they were cleaned properly and they are clean. There is no restriction in the jets, main or low speed. These are fixed orifice jets by the way. So why do the jets require the aid of choke to allow fuel to flow through them?
Thanks for your help!
GB
GB
