Hi, this is my first thread on iboats. I have read several threads prior.
Sorry for the long thread I just wanted everyone to have all the facts in hopes we can narrow down the problem.
I have a 1973 larson boat that has a 1973 65 hp johnson seahorse outboard motor.
I bought this boat last year and it had sat for about four years. The first time I took it out it ran great. The second time it ran great for 2 hours and then it wouldn't go into high gear it would bog down as if the fuel was restricted. So in responce to the problem I began trouble shooting and repairing. I first checked for compression and spark 115 psi on all three cylinders good spark from cable to spark plug. Replaced spark plugs(champions no spark gap), changed impeller and gear oil I usedpremium type C oil and an OMC impeller(no metal shards or milky substance old impeler still in good shape)bought a new prop, bought a new gas tank and primer ball omc/johnson quality, replaced the fuel pump and fuel lines, rebuilt all three carbs. I used OMC parts no after market(found a small shard of metal in the high speed jet of the top carb) cleaned and recleaned, adjusted floats so they were level when turned upside down, replaced caps, low speed and high speed jets I believe are fixed so no adjustment, all in all total rebuild. I very carefully mixed 16 oz of johnson 2 sroke oil in with exactly six gallons of fuel. pumped the primer ball set the lower unit into a tank of water and turned the key. It fired right up (with the warm up lever down)after 2 or 3 crankes and idled perfect. I eased into reverse no problem. Eased it into foward no problem reved it up for a second no problem. Then I shut her down because my tank was loosing water. I pulled the motor out of the tank and it sat for about 3 days. Yesterday I go to the lake (2 hour drive). Before I left I put earmuffs on and started the motor and let it idle for less then a minute it fired right up with warm up lever down idled perfect. I get to the lake fires right up goes into reverse with a little trouble not bad goes into foward no problem. I take to the dock and shut it down while I move my trailer. I go to restart and it takes forever to keep it idleing and when I put it in gear it stalls and dies. After 5 minuts or so I get it in gear and away I go I get just outside the no wake zone and it stalls and dies I trie for about an hour to restart it idles decent but when I put it in gear it stalls and dies. My primer ball seems to be going limp after it idles for awhile not completley limp but just a little its not rock hard. The vent on my gas tank is open and I see no gas lines leaking. I did try adjusting the idel adjusment screw but had no luck. I also adjusted the idle lever adjusment to get a higher idle because at the lower idle it would die.
I had to paddle back to shore and my wife who was with me was not happy about that she wants me to sell the boat but I feel like I am so close to fixing it. Problem now is I don't no where to begin any help is greatly appreciated and thank you in advance ss mino
