pupps-power
Thread starter- Joined
- Jul 7, 2009
- 2
I am a new member so please forgive me if this questions sounds stupid.
I have three wires coming from my throttle body, a green. blue and red.
I recently replaced the green cable connector that leads to the solenoid on the engine.
Now my tilt does not go down. It goes up fine.
I changed the leads around in the mid way connector so when I opearte the down switch on the throttle body it goes up (so I assume its not a problem with the switch itself.)
I then took the blue connector (which works) from the solenoid and put it on the green solenoid assuming it would go down when switch pressed up but nothing.
It worked fine before I replaced the connector onto the solenoid.
Aso what does the red cable do?, It has a fuse connector by the solenoid, when this is taken out the tilt stills goes up.
Anyone any ideas? So frustrasted.!!!
