Bifflefan
- Joined
- May 27, 2009
- 2,933
The tab behind the prop is used for steering correction, is it not?
If so then by adjusting it in the opposite direction of the torque it should help to cancel this out and be a little less tering to steer, correct?
There are also numbers on the bottom ranging from 1 to 8 (i think its 8) as referance markes. but if i were to set it at 0 it would angled (from stern) to the port side. is this the right way to move it to help correct starboard torque steer?
I only ask before i move it as i dont think i could hold on it for long if the torque steer got worse. Shes a 2 hander, or at the very least a real good grip with one at anything over 2500 RPM.
Also if im not refering to it with the correct name please inform me of it.
