Re: Steering adjustment on a 1992 Merc
Thank you for the info.
Just so I have this correct.
You disconnected the cable at the motor and the helm, and then from the motor side you flushed it with Dexron Tranny fluid until it dripped out of the helm, then, with your rig and compressed air, you put 10w30 synthetic oil into the cable. Did you let the 10w30 drain out before connecting the cables back up?
Thank you for the help
Chris
That thread is a composite of folks talking, and some doing. You really have to sort it out. Basically we experimented and brainstormed together and came up with solutions.
Success is achieved by forcing a really thin penetrant through the dirty cable. I and others used SeaFoam successfully. I suspect WD40 might work, but it might be too heavy. When the cable starts to clean up, an ounce a minute or so will go through at 120 PSI. I flushed it 3 times. If you can move the cable while the pressure is on, it helps break up the contamination.
Then you load up the tube with the lubricant. I used 5w30 full detergent (wally-world) motor oil. It takes 10 - 20 minutes for any oil to show up in the drain pan at 120 PSI. Then it's lubed. Don't force the oil out with air pressure. Leave it in the cable as lubricant.
You need a light lube with a fairly high film strength. If I wind up doing this again, I think I will try Alisyn 0W gear lube. The motor oil seems to work fine. We'll see what the life of it is.
Some made their aparatus from a piece of tilt tube welded to a piece of 3/4 in pipe. I found a 3/4 inch flare fitting had the right thread, and by drilling it out, and counterboring it slightly with a step drill, I got a metal to metal thin edge oil-tight seal at the cable. To that I added a FPT to 3/4 copper adapter, a couple feet of 3/4 inch copper pipe, a 3/4 copper to 1/2 in FPT adapter, a 1/2 - 1/4 in threaded bushing, and an air fitting.
Some used a T and a plug to introduce the fluid. I chose to combine the plug and the air fitting.
I had thought about making an adapter that would go right onto the tilt tube on the motor, but decided not to because most of your steering contamination is in the tilt tube. You really need to disconnect the cable, even if it means swinging the engine, and seperately clean out the tilt tube.
Likewise, clean as much crap off the rod end of the steering cable as you can before you force penetrant through the cable. Just less stuff that has to go through that tight space.
hope it helps
John
