86 225 no pulse
chief08087
i got an 86 evinrude 225 and the pulse line going to the fuel pump dosent put out enough air to work the pump. one minute it will work the pump and the next it wont. can beat reeds cause this?
jonesg
Re: 86 225 no pulse
Get the factory manual
www.outboardbooks.com
the best $45 you'll ever spend on your engine.
follow the hose, there should be a check valve at the block, flush it and check for one way flow, clean hose out too or heck replace the whole lot.;)
