what all has to be changed 86 alpha to 92 alpha gen2?
lime4x4
I currently have a 86 mercruiser alpha.While looking at it today.I c i have alot of play in the upper and lower hinge pin area plus my outer transom plate is starting to show it's age. I have a 1992 boat with an almost brand new alpha 1 gen 2 setup. Can i just install the whole outer setup? The shift cable looks the same between the both of them. I know i'll have to use a alpha 1 gen 2 outdrive.
TilliamWe
Banned
Re: what all has to be changed 86 alpha to 92 alpha gen2?
Everything will have to be changed.
Ayuh,... From the rear motor mounts Aft needs to be swapped...
lime4x4
Would the exhaust pipe need to be also changed over?
Ayuh,... I Think I gathered that 1 of these is for an Inline motor,+ the other is a V-motor...
Yes, the exhaust will be Different...
The Gen.II has 2 more bolts through the transom....
Maybe those new bolts line upwith the older transom plates,... Donno....
