I have had my boat for about a year and a half. Before I bought it, I test drove it and it ran great. The first time I took it out after I bought it, a cylinder was hydro locked. I have a Seakamp fresh water cooling system installed on my 4.3L GM Vortech V6, 262cid. It is in a 1993 Sea Ray 200 bow rider. The only part of the engine that is raw water cooled are the exhaust elbows. When the cylinder was hydro locked, it was because the block off gasket between the exhaust manifold and the elbow failed. We took our time and replaced the gasket and kept on boating. As time went on last year, you could tell the gasket was failing again because the engine was burning anti-freeze. It was always hard to start because anti-freeze would leak down into the cylinders, get the plugs wet, and make combustion very hard at the beginning. At the end of last year, I ripped it all apart again and replaced the gasket. I know I used a mercury replacement part both time, but cannot remember the exact part number. If I remember correctly part number 27-860231 replaced 27-41811, because the new part no longer required both the steel plate and the gasket. From what I read, the new parts that are gray, contain graphite, which is why you don't need the steel plate. At the beginning of this year everything ran great. As the year has gone on, I can tell the gasket is leaking again because it is hard to start and burns ant-freeze.
Does anyone have advice as to if I may be installing this gasket wrong or how to make the gaskets last longer than 2 months of use? It really sucks having less power and hard starts because of the anti-freeze in the cylinders. Not to mention, the extra wear on the engine. Any help is appreciated.
