evinrude 60 hp losing power after 10 minutes
augusta chris
I am having a problem with my 60 hp evinrude 1993 bass tracker losing power after about 10 minutes of operation. The motor acts like it is choking out and losing power after a few minutes of driving. I have cleaned all fuel problems in that I have cleaned the tank and I have 2 in line fuel filters and a water separator installed. The carbs are in perfect shape. Clean as a whistle. all seems to be right, I just am at a loss. any help would be greatly appreciated
dr1077
Re: evinrude 60 hp losing power after 10 minutes
did you try to change the condensor, sometimes they get hot and shut your motor down
Daviet
Might try squeezing the primer bulb when problem happens, if it helps, might want to check your fuel pump operation.
mrcj001
Could be a ignition problem. When the engine gets warmed up, a ignition part could be failling.
mikesea
it could be your tank is not venting properly ,try loosening the cap when problem starts,if it corrects,fix your vent problem
