eight tracker
- Joined
- May 12, 2009
- 81
Re: Correct terminology .... "Motor" or "Engine"?
an engineer drives a train!
An engine is a motor. A motor is an engine.
Ditto. That's the way that I've always heard it denoted in the engineering world.
saying a motor is powered while an engine is fueled isn't really straight forward either. They both take an energy source and convert it into motion. There really is very little difference between an electric motor and having to put new batteries in, vs a fueled engine that you have to fill up the tank. And then you end up with the fun of a hydrogen fuel celled vehicle. Try classifying that one with that analogy!
Thus, the outboard would technically be a motor, as it's driven, it just carries it's own engine.
An outboard is an engine bolted to a transmission with a propellor at the end instead of a wheel or gear (a powertrain). A person wouldn't call the transmission, drive train and wheels of a car a 'car motor'. If fact, you wouldn't call it anything, you would call it a 'car'. It is assumed it has those things, and outside of that car it is called an engine with a transmission, drive train and wheels, the combination (without missing parts) being called a powertrain.
So I guess to be correct in the description an outboard engine strapped to a transmission, drive train and propellor would be to call it an outboard powertrain (all items in a combined package). We just call it what takes less time to spit out, I would guess, making it slang.
So next time you call an outboard an outboard motor, you can consider yourself a slang-talkin' hippie!![]()
According to the dictionary a motor is an electrical device converting electrical energy into motion. An engine is most all other devices described here. I was a mechanic for an entire career and thats how it was described.
Bill
