rogerwa
Thread starter- Joined
- Nov 29, 2000
- 2,339
Here is the backgorund..
The motor is on a 25' pontoon.
WOT is at spec or above empty but I can do 5200+ with a normal load of 6 people. It runs great at RPMs over 2K and can run all day.
Compression on motor is an even 120 across all three cylinders, I have soaked and put carb kits in last year. I have checked all linkage lenghts.
The Carb needles are set at approximately 1 3/4. This seems to be the best setting. Any less and it does not idle and will sometimes caugh and die (lean sneeze). It idles out of gear at around 1k to 1.1k and 800 in gear.
Here is the problem..
My cabin is on a river about a 20 min boat ride from the lake. When I sart it cold, I wll lift the idle lever up to get it started, while giving it choke. I run it at aournd 2000 RPM to let it get warmed up and slowly reduce the RPM until it idles without the idle lever raised.
When I idle to the lake at no wake speeds, which we cheat a little bit and usually idle at about 1500-2000 RPM, the motor seems to be bogged, needing to be cleared out. it runs like this until I get to the lake and then when I increase speed, it "clearsout" and runs great. Even at idle.
Also, I need to run it tilted up so that it is not so deep inthe water. When I put the motor in the down postion it smokes terribly from the exhaust relief port. I can only guess that is because of exhaust back pressure.
From my observations, it would seem to me that this is running rich at idle, yet when I adjust the idle mix screws to the lean, it doesn't run well at idle.
I am looking for idea on where to look to resolve this. I just replaced the plugs this past weekend and they were pretty oily.
Ideas??
Ideas??
