dperkins8694
- Joined
- Jul 9, 2009
- 12
I have had my 79 7.5 merc for about 2-3 years. Got it from my father-in-law who only ran it once and it set for 7 years with fuel in the carb. At first the little engine that could ran great, then it started not getting up to speed. So this winter I rebuilt the carb, spring came put it in the water ran great for 2 minutes and then back to the way it was running. So I decided to check the compression and noticed I was leaking water from the rear of the engine. So I replaced all the gaskets. Checked for spark from both plugs, the lower plug was not getting any spark. Tested the coils and everything pointed to the switch box, replaced that yesterday, great spark starts better than it every did. Now for my problem, its not peeing. I had it in a 40 gallon trash can, did not let it run long 2 maybe 3 minutes, the engine was not getting hot. I was able to hold my hand on the block without removing. Drained the can and forced water through the muff hole and the water filtered through. Filled can again, no peeing. Prior to the gasket change as soon as you stated it it would start peeing. Am I not allowing enough time for the water to push through? I dont want to burn anything up. Any help would be appreciated, thanks.
