1999 Johnson 150 Oceanpro Ignition prob/maybe??
Upsmatt
Well I have spent the last week dealing with my mechanic but we have not fixed the boat just made it worse...here is my prob...the boat is a 21ft welcraft with johnson 150 at WOT the boat would only hit about 4300 rpm trimed up and only about 18mph. So I called the mechanic he did comp and that was fine...but then checked spark and said I had no spark in #2 cyl so he imediatly told me I needed new powerpack so he replaced...did nothing then he said needed new optical eye so replaced ...did nothing please shoot me some suggestions any help would be great. Also when replacing powerpack , optical eye, and stator do they have to color cordinate...some have grey, some have blue and some are black ....thanks again for your time
Re: 1999 Johnson 150 Oceanpro Ignition prob/maybe??
what about the coil to @ 2? i think i would have gone there before power pack.
Upsmatt
I will def check that today...thanks for the response I will let you know how it goes....
another todd
First and foremost, you need a new mechanic. Check as mentioned the coil, plug, and plug wire.
Upsmatt
well now instead of just #2 cyl not firing its the whole left side of my motor so 2,4,and 6 cyl are now not firing any suggestions? I have tried new power pack new optical eye and new stator...no help
jonesg
Unplug the shift interrupt switch.
Located on the shift mechanism , lower starboard side.
Try again.
Upsmatt
will try that in the morning thanks again for the help
jonesg
whatdya mean "in the mornin"
get out there with a flashlight.:p
Upsmatt
that fixed it thanks for your help
