billy4hp
- Joined
- Jan 31, 2009
- 245
Just fishing for some suggestions on what I should or should not do...
I have a 1978 Johnson 70hp 25" shaft mounted on a 1972 Glasply 16' deep V runabout. For those of you not familar it is a very deep V boat with full length spray rails for ocean running, it is designed to have alot of hull in the water to cut through the expected rough water. The dashboard / controls are forward in the hull, much further than a comparable Bayliner or similar runabout. The boat weighs around 1000lbs dry without engine or gear. I normally carry two 6 gallon tanks in the rear, marine group 24 battery, I have a 5 hp Nissan kicker mounted on the transom as well... I carry the normal ice chests, anchor, ropes and gear the Coast Guard up here expects us too. Usually for passengers I have myself and atleast one of my two boys (only 6 years old on my oldest).
The boat currently has what I believe to be the original 13 1/4 X 17 prop. In it's current position the caviation plate is flush with the bottom of the hull V. The engine has no power trim although I have played around with the trim bar and have found my happy medium for speed and control. The boat has Bennett trim tabs to push the bow down in rough chop for a smoother ride and to control listing with a heavy load (or passenger).
My engine is rated for a 5500 rpm max @ WOT. I can get nearly that (54XX and change on a smooth surface) and run around 36 to 38mph... Running with the current through Deception Pass I do get the joy of travelling 45mph
My question is I have read where a boat will run better with the caviation plate above the bottom of the hull surface? Also I am sure there have been plenty of achievements in prop design since 1978.... So how much am I leaving on the table with my current setup? Will a newer 13 1/4 X 17 prop give me a noticable increase in performance? I have been planning on buying a new prop just as I believe I am running on borrowed time with the original 1978 prop as far the the rubber hub goes??? Since we can get a few miles offshore it's advisable up here to have a replacement prop anyways just for a comfort factor...
Too be honest most of my running in the ocean is well below my WOT max as water conditions can get kinda nasty in a hurry or if a fleet of 36 foot plus yachts are running around you have instant 3 and 4 foot seas. So for the information I usually run around 26 mph @ 3600 to 4100 rpms (saves on fuel too)...
Thanks for your time,
Billy
Billy
