duanedragon
- Joined
- Jul 11, 2009
- 2
Hello, I'm a new forum member and would like to get some input from people with more knowledge of outboards than I have, (probably aren't many people with LESS knowledge- lol). Would a large multi-cylinder 2 stroke outboard motor function bolted to a Volkswagen Beetle's trans-axle? I've been considering re-powering with a Mazda rotary engine but I figured that if I'm already going to crap in my hand and wear it as a hat I might as well explore some even stranger power sources. I've noticed that some of the outboards are making 250hp which is enough to push a Beetle to low 12's or even mid-11's on street tires and pump gas. Kennedy Engineering make adapters for Volkswagens for just about any engine and would probably fab up a flywheel and clutch assembly if I asked nice. There are already some significant problems that could render the vehicle an un-drivable trailer queen. The cooling system would have to be built from scratch, (Mazda rotary engines have terrible thermal efficiency and put out huge amounts of heat so anything that works for that swap should be more than adequate for a large 2-stroke). Re-powering it would turn the vehicle into a one-off parts and maintenance nightmare rivaled only by Fiat owners. VW trans-axles have 4 widely spaced gear ranges that would not be well suited to a 2-stroke's inherently narrow power band. Large 2-strokes are very expensive. Correct me if I'm wrong here but 2-strokes lower end oiling is done via premix and the crank and rods would scuff, heat up, and turn into molten slag if they had to oppose the force of moving an automobile. Premix on the street makes a car look like it is either on fire or is powered by coal, plus it's a drag to have to add premix even if it is automatically metered. If the bottom end is oiled via premix then the engine could be mounted with the crankshaft horizontal instead of vertical and everything should be fine assuming that the fuel delivery system be altered to work in the engine's new inclination. Man oh man, the more I think about this the worse it sounds. The engines look very light and due to a Beetles low weight, (1640lbs with a full tank), it might be a mean little hummer. This could possibly be the stupidest thing many of you have ever seen and I am willing to accept public ridicule if it saves me hassles down the road.
Thanks!
Thanks!
