Freezing Mercruiser v8
cruisa
Hi guys, Thinking of buying a boat with a 2005 merc v8 5.0L 220hp mpi with alpha 1 gen 1. Engine only has 36hrs and outdrive is 1988 origonal. This will be the first engine i have that is raw water cooled only and my concern is when i come back from sea, salt water, the engine is flushed by the river at my mooring, fresh water, is there a danger of freezing water in the block as the boat is in commission thoughout the winter. If so how can this be avoided?
Any help much appreciated :eek:
mkast
Re: Freezing Mercruiser v8
Fresh water cooling system, Does the river freeze? The sterndrive.
cruisa
No, the river doesnt freeze but the air temp can get as low as -10c
cruisa
So is the solution to retrofit a heat exchanger and closed loop with glycol? There is a drain lever on the front of the engine to drain the block water into the bilge but is this enough? The boat is normally in commission through the winter. Cheers
rbh
if the temp can get down to minus 10 c you are probably on the west coast, van isle?
if you have shore power look to see if they make a circulating block heater (like they use on cars ) that you can cut into the system?
rob
Even with a heat exchanger, you can have freezing problems with the water on the raw side of the heat exchanger.
What do other people use at your marina?
cruisa
Thanks Rob, no im on the south coast.......... of England :) I don't have shore power available. Will the block drain work or do you think it will leave too much water in the engine. Have had outboards on the mooring for ten winters without a problem but i assume they drain automatically. Glenn
rbh
we generally plug our cars and trucks in when the temp goes down below the 10c-20c mark. we have a choice between a circulating style heater that moves the glycol/anti freeze around or the more common block heater, you pull out one of the middle frost plugs on the side of the block and tap the plug with the heating element in its place.
they are usually 750 to 1500 watts to run.
if you use a circulating style hopefully it would pull the water in the leg, heat it and the block and leg on its way out?
or just pull it out of the water and drain every thing.
rob
cruisa
-10 to -20? thats much lower than what we get here. -10c is the worst case, maybe once or twice per winter. sometimes we have -3 for a few days but average temps are between +3 to +6. maybe im worring for nothing? The heater sounds good but I have no power available. Glenn
FreeBeeTony
Is it fresh or salt water?
EDIT........I see you are in a river after the sea.
gadget73
I'd go with a fresh water system that includes the manifolds, and get in the habit of draining the raw water side of things after each use. A block heater wouldn't be a bad idea either, it should help keep the engine compartment warm enough to keep any residual water in the lines from freezing up. You're still risking having water freeze in the area around the transom assembly and where the water hose connects from the drive itself into the transom assembly, as thats above the water line in some parts. Not much to be done for that, but a hose is a whole lot cheaper to deal with than a cracked engine block.
Ayuh,... That'll Work,... But you might have to add drains Merc didn't include...
And,...
They should be so that they can be rodded out with a screw or nail,...
Just so they don't get Plugged...
cruisa
Thanks Bond-o. Think i will go with that. best places to add drains on a v8 block? Thanks all for your help. Glenn
