Where can I buy this? OR fab it?
Re: Where can I buy this? OR fab it?
Ayuh,... I imagine Volvo will Sell you 1....
I'd probably hunt up a piece of soft copper tubing,+ make my own....
Don S
#8 in that picture is a seal, I assume you mean #6 ????
attachment.php
If so, it is still available although on backorder till 7/29 and you can get it from a VP dealer.
PN 855414 SRP $208 :eek: :eek:
PN 855414 SRP $208
Ayuh,... Like I said,... I'd build 1.....
krisnowicki
well fab it , it is. 209 is redic for a 8 inch piece of copper.
stonyloam
If it is just a hole or a split, I would think any good plumbing shop should be able to solder a copper patch on it.
Don S
I think you are going to find that fabing that piece to fit and actually seal and not leak at either end is going to be a lot more difficult than you think. But good luck, and hope you get it made.
That is a big problem with the Volvo 4 cylinder OHC engines. Parts prices are rediculous.
Ayuh,... Good Point,... A Repair might be Easier,+ probably Cheaper....
Depends on the Damage....
Why silver solder? Normal (lead and tin) won't stand up to the vibration for any length of time.
Hmmmm,... My 1st thought was to Braze it.....
'course, I carry a set of Blue-Tip wrenches,+ a few Lb.s of coated brazing rod on my pickup/ portable Toolbox.....
Robj
Call me ASAP if you still want that pipe. Check your PM for my contact info.
Have a great day
Rob.
