mnessman
- Joined
- May 12, 2008
- 62
I need ideas ato what is wrong with my motor.....I have a 115 hp evinrude that i jsut recently put on a boat a couple of weeks ago, I have had the motor for a year but have nor had it on a boat so I dont know the history of the motor. The problem that I am having is when we first put the motor on and took it to the lake we had problems idling along with slow and high speeds. We checked the spark plug gap and found it to be wrong so we regaped and tried it again. The boat ran better at low speeds but still had problems at high speed. I noticed that the upper carburetor was on barley spurting gas in one of the barrels but the other barrel along with the bottem carburetor was purting gas pretty good. Since we did not know how the carburetors looked inside we rebuilt them and put in a new fuel pump along with all new hoses. I had also noticed a water leak at one of the heads and replaced the gasket, so their are no water leaks now. After the carbs were rebuilt and the new fuel pump in place we took it back out. It seemed to run better although it seemed a little rough but when we tried to open it up it would start to be doing good then it would fall flat on its nose then it surge again. The engine would keep this surging action, if we idled it and then went to fuul throttle it would start to good and then it would just die down again. I dont think that the tach is working right so I can not give acurate rpms when this would occur. I haent checked the compression yet but will be doing that shortly. If any one has any ideas on what the problem is please let me know. Thanks for the help.......
