Motor Swap??
Sparkscw
So I have an 89' 2.3L OMC with a cracked exhaust manifold. I am looking for possible solutions ( I am aware of the parts availibility issues).
I am now wondering about an engine swap to a OMC 3.0L and I have not been able to determine if the OMC outdrives are the same. I have been able to determine the exhaust is on the oppisite side.
I am looking for schematics on the setups for comparrison or other options.
Anyone have any ideas.... other than just putting a 9.9hp kicker on and trolling for ever.
maxxman04
Re: Motor Swap??
bout the easiest, and most cost effective, as i am doing this same thing myself, is find a donor boat with a good motor/outdrive, and swap. if you get the entire setup at once, order necessary gaskets/impellers/ misc. parts, the swap really isn't all that hard. hardest part might be the motor mounts, glassing new ones in if needed. mercruiser will bolt thru the omc cobra transom.
Sparkscw
Re: Motor Swap??
Thanks for the info. I have some leeds on parts to fix what I have but I have been unable to find a source for the gaskets or for that matter any other part for this 2.3L.
Sparkscw
Re: Motor Swap??
OK answered my own question and found the parts, I just had to learn to ask the right questions.
I found them all on marineengine.com (much cheaper)
And some on go2marine.com not all of them though (more expensive).
Now I am debating on the exhaust manifold from Hi-Tek......
