Just purchased a boat with 85HP Chrysler Force Outboard i think is 1989, it had been sitting for 4 years without use. Motor cranked up after disconnecting kill switch. The boat was in shop for 2 weeks. I took the boat out for a drive and when started to speed up I heard a loud (hard)knock coming from motor, it was like a sound if you hit something. Took it out again, and started doing same thing just some loud knocks sometimes when sped up,this is not a constant knocking sound, just Second time out right when I put it into idle it made two hard knocking sounds and died. Then got it started and headed in but not far drive at all and it felt a little like I was dragging bottome some, I know for sure I was not hitting anything or had not hit anything becasue in 26ft of water. I checked the prop and nothing wrapped around it or anything. On the day that the mechanic was bringing the boat over the horn went off, so he replaced something to keep it from overheating. Another problem is that when I trim the motor up while it is docked the motor slowly falls back down. Bill shows that compression was checked and okay. It also makes a spitting sound when trying to start up when cold but mechanic told me it will do that when cold. Amazingly the carbs where in good condition. Another thing is that my dad put gas in the boat mixed in with gas that had been in boat for four years.
