I have a 1983 dyna track with an evinrude 115 nearly perfect condition until i discovered a rotten transom... thank you Nida-bond if you have never used it try it out.. once the transom was finished i put a 6 inch hijacker on the transom. during the test run with the jack at it lowest setting it appears to be catching too much air (does that sound right?) well the engine rpm is too high and appear the engine needs to be lower in the water. when we bout the boat new it had the same problem and the delaer placed shim plates between the engine and transom and advised the engine needed to be under the boat more. does this sound right? the question I have is when can one tell when the motor needs to be lower or when a larger prop is needed?
