Alpha 1 Trasom Leaking
sunkone
I'm new to boating this season and I attempted to haul out with the out drive down, dragged it a couple of feet stopped ,and then decided it would be a good time to raise the out drive. Except for tearing the ends off two blades of the prop I thought I was okay, but now there is a major leak. I launched today and could hear water running into the bilge, gallons. Right back on to the trailer and back home.
How much damage did I do? I'm calling the shop this week but wanted an idea of what I going to hear.
Bt Doctur
Re: Alpha 1 Trasom Leaking
Depends on whats leaking,transom housing gasket needs the motor to come out and the housing removed to re-gasket it.May have broken the mounting bolts or studs, may just be a boot thats leaking.
mylesm260
You may have also popped off a bellow. That could definitely cause a leak.
WAVENBYE2
You tore of two blades? that means your skeg is gone too???
sunkone
No, the skeg is still there it broke about an inch off the tip of two of the prop blades and 1/2 inch off the skeg. The prop blades got stuck in the grooves in the ramp and broke off when I raised the outdrive. Good thing for alum props.
It in the shop now, no word yet. I hopefully it is a bellow and that I didn't do serious damage. Used boats are the best.
