silver_power
- Joined
- Jul 8, 2009
- 327
Hello to everyone and congratulations for this awesome forum.
I am from Greece and i own a 1993 wellcraft nova spyder with 5.7LX 4bbl engine.(260hp@crankshaft). The boat is in GREAT condition and i really love it the way it runs at travels (22deg V). With this engine reaches at speedo 59mph@4600rpm with an 22p enertia (at speedo). All these until last year that my engine was ruined. So i decided to repower it with the new 350mag mpi.Mercury said that this engine is fully compatible with my Alpha one genII drive (gear ratio 1.47:1) and so i bought it and now i am waiting for it . I also got smartcarft gauges (sc1000 speedo-tacho and the link sc100 gauges). The engine instalation will be made by me as the instument installation.
I want to ask you what opinion do you have about the specific engine (350 mag mpi) consernig the power and the fuel consumption and what speed should i expect with the same prop.I believe that the prop will be ok and the new engine will reach 5000+rpms. Second question is about the pitot speedo sensor and also the fuel level sender. Where am i going to connect them, since the new gauges take data from ecu. So, somehow i need to connect the pitot sensor and also the fuel level sender with the engine and not directly to the gauges as it is now with the old gauges. Are there any specific inputs (leads, or anything else) around the engine particular for these sensors? For example, i know that the smartcraft depth sensor (transom mount) that i also bought will be connected at a terminal side to the smartcraft link terminal at the ecu of the engine.
Every answer would help me very much during installation.
Thank you very much in advance.
