thundercraft260
Thread starter- Joined
- May 29, 2009
- 10
my boat 92 thundercraft 260 express 5.7 merc bravo-2
the boat was working fine until the end of the day, then all of a sudden I could not trim up my drive unit. It will trim down no problem, but to trim up it will only work using the trailer trim. I had the pivot pin,gimball,bellows & etc repaired/replaced last month. So the whole assy was appart...Can it be the limit switch & if it is do I have to remove the boat from the water to repair/replace it or is it sealed and won't leak...? Is there a connection in the bilge as I was fumbling around changing the oil the day previously, could I have loosened a connection and id so why only the trim up position?
Thanks for your help....going on vacation with her next week
John
John
