Re: 1976 Starcraft SuperSport 22' Overhaul Lotsa Pics
Wedenesday 7-15-09 off work today so i got a huge head way on the deck. i told ya id show ya a lil trick to stiffen up a 1/2 floor and save weight over 3/4 inch floor. pictured below is 4 2x4x8 split in half long ways these lil wonders help me create a ladder system effectively reducing the load by reducing the span. i dont understand how starcraft thought spanning 2 feet at some points would stay rigid. but anyhow here some pics
got my load a lumber also found some 5 ply 1/2 at my local lumber yard. home depot only had 3 ply. remember not all 1/2 plywood is the same. 5 plys way stronger than 3!!
then i ripped 4 2x4's for my cross bracing
also i dont know if you guys use this caulk or not but i use it over any marine stuff 5200 4200 whatever this is better IMO and at 4.50 a tube i dont have to remortgage the house. its a polyurethane based and never seperates or release like silicone would i found it to be a very similar makeup of the marine grade stuff
step one was to go down the stringers and cross brace everywhere there was a seam i doubles it up and yes i will still use the metal strips from the factory
