The engine sounds like it is runnining out of gas. I can get the boat on plane and run for about five minutes and then the engine bogs. I can pump the bulb and it will do the same thing again. I had someone pump the bulb while we were running and as long as he pumped the bulb every few minutes the boat would run fine. Im thinking maybe a bad bulb or bad fuel pump. Also can this engine be fitted with the old style fuel pump and do away with the vro pump? We have been mixing the oil and gas for years and dont need the vro. Any suggestions? Thanks
