Merc 165 1981 trim position guage
theboatcarpenter
I have a brown/white wire that is disconnected and i believe to be part of this equation. I also know where my two wires are from the trim sender switch coming from the stern drive. This is the L6 165 merc. In 12 days I have replaced the up solenoid, reconnected the trim limit, replaced fuel pump filter, in-line fuel filter, adjusted and cleaned the carb, replaced the blower, valve cover gasket, refinished the teakwood, so i am getting close to finished so please help.
xltier
Re: Merc 165 1981 trim position guage
i believe there is suppose to be a brn/wh. hooked to one of the black wires from the trim sender.
Wakesilver
My aftermarket manual shows one side of the sender hooked to black going to positive on the battery.
Second side of trim sender is hooked to purple/white going to indicator
Indicator is powered by accessory side of ignition swith
I also want to say indicator is also grounded.
I had to rewire mine, I think the signal from the sender was disconnected.
Your wire colors may vary.
Congrats on the repairs, hope you can enjoy them soon.
ziggy
where was your up solenoid for the trim?
coming from the pump. the up sol. would be the one with the blue wire attached to it..
